1 - 17 of 17 Posts
· there is no spoon
· PWN3R
mirrored picture
· there is no spoon
Discussion Starter · #7 ·
its mirrored.
· there is no spoon
Discussion Starter · #9 ·
yes
tobefast.com
i think they are between 700-900 depending what cans you get
· Habs for life
Micron Slip-ons
I installed Micron slip-ons, and they are a sweet sound. No probs to install, except a couple of washers were needed, or should i say added for clearance, as i didnt want the tail section to be to close to the exhaust, and cause any heat damage. Its still cool up here Canada so for now it wouldnt be an issue, but better safe than sorry. Polished aluminum on a silver R1...just what the doctor ordered :thumbup
Cheers
· there is no spoon
Discussion Starter · #13 ·
they sound even better with the smog plates installed.
· Taming the Beast.
Hey Christian,
What map are you using on the PCIIIUSB? I have the same set-up.
· there is no spoon
Discussion Starter · #15 ·
i use the graces full TI map, but i made 2 adjustments, at 1000rpm and 1250rpm at 0% throttle i increased the fuel by 10% i dont have the map with me at work but can email to you if you wish on tuesday.
· Taming the Beast.
Yes, please do!
I'm currently using the Micron Full system Euro map. It seems to surge a little at idle and I think it might be a tick on the lean side.
· there is no spoon
Discussion Starter · #17 ·
here is the file as promised.
the pc3usb map i am using
1 - 17 of 17 Posts
