Removed the muffler cover and ground off the brackets, took a while to do but the results are pretty good. The welding distorted the metal a little and it shows slightly after I removed the brackets.....but only if you look for it.
I do not recommend doing this unless you have a die grinder, cut off wheel, flapper wheel, duct tape and cabinet sand blaster.
