1 - 9 of 9 Posts
PWN3R
rear pegs bud
I can't attach it to my rear pegs because I'm getting rid of my passenger pegs, I'm wondering if there is a kit for your swing arm.
WHERE'D WHO GO?
send me your 04 R1, I will "fabricate" a bracket to attach anywhere you want.
WHERE'D WHO GO?
Honestly, the only thing I can think of is to weld it on. If you pm me some pics of your swingarm, i might be able to try and make one to attach somehwere. i just do not have acces to an 04 to look at.
What i did on my 03 r6 I welded a bracket out of some square steel the same size of the plate, and bolted the plate to it. Than I screwed it into the rear spool hole it holds it up fine looks Awesome too. I also made a little bracket for a libertek led light.
SpidermanSS killer.
OK that makes it even simpler. Run a bolt through the hole for the rear pegs(that you deleted) andattach it to where the rear pegs were. I have no pegs and mine mounts the same way as if I had rear pegs....
1 - 9 of 9 Posts
