hey guys, its been a while since iv beenon here. sold the bikes and paid off some school stuff.. just recently picked up another 2004 R1.
about the bike : 04 r1, full graves exhaust, V-stacks, PC3. just under 15xxx miles.
work done: fresh oil change 20 miles on it, plugs- unknown, valves checks by shop right before i picked up the bike, i have the receipts.
ok so my issue was when first riding, takign off from a stop, it would stall tryign to feather the clutch out, sometihng was off, it was ifling like a big block with cams.. really uneven. the idle was set to 900, i adjusted it back, i found that i like the way the bike responded if its slightly igher then rec. in the manual, so its now sitting at maybe just a tick above 1500 when warm. thats ficed the stalling but that didtn fix the uneven idle.
pulled codes and got lean angle sensor, intake press sensor, battery and sidestand. respectable since the kid before me did drop the bike but never cleared them out.
next issue, the power commander was plugged in but not corrrected correctly groudn wire was never attached. put that back together and kinda fixed the idle but not much. changed the map over to the graves map from the pc website.
im suspecting maybe plugs i jsut havent had time to check but my main reason for posting is what is the norman function of a pc when the bike is turned on. sounds stupid but when power mine up, it scrolls from bottom to top but then just sits at the half way mark and doesnt move with throttle input.
has anyone had a pad power commander? and can someone describe the correct function of how its suppose to work. iv have them on other bikes and i did install this correctly but i just want to make sure that this is not a PC issue. and yes, the idle doesnt change whether it is connected or not.
