SR (Stock Replacement) - Zero Gravity's® new line of stock replacement windscreens, called the SR Series, embodies the best of ZG's original XL and TL lines of sport bike screens. Shaped like the original OEM screens that come stock from the factory, SR Series screens feature the best optical quality, fit and finish of any in the world. Zero Gravity® stock replacement screens are factory pre-drilled and designed to fit your OEM fairing with precision using your stock mounting fasteners. Available in clear or smoke.
DB (Double Bubble) - Because the Double Bubble™ concept had proven itself on the track and provides a unique look for the latest designs in sport bike styling, Zero Gravity introduced a line of Double Bubble™ windscreens in 1997 for most modern sportbikes which can be used for street or track applications. The Double Bubble™ series is in an ongoing development stage. The windscreen appears as a "bubble within a bubble" which is exactly how this windscreen is fabricated. If you don't see your bike listed, give us a call. Chances are we're working on it.
ST (Sport Touring) - Because most modern sport bikes are designed as replicas of racing motorcycles and are not intended for long distance comfort, Zero Gravity® has introduced its Sport Touring™ Series of sport bike windscreens designed to reduce the windblast on the rider and provide more comfort while in the upright riding position. Because no two humans are alike, it is difficult if not impossible to predict precisely how these screens will perform for any given rider. What we do know is that our tall windscreens will raise the point at which the wind will hit the rider by several inches and will significantly reduce the windblast on the rider. Buffeting and other aerodynamic considerations will vary according to the riders' physical dimensions. Made to the highest Zero Gravity® standards, each Sport Touring™ screen is designed to enhance the look of your sport bike as well as provide better rider comfort.
