1 - 11 of 11 Posts
Its Master To You
Hey guys,
So the story is..... I havn't ridden the bike in about 2 weeks, yesterday I got a new tire put on and rode this morning. Coming up to get gas the bike just cut out as I pulled the clutch in. It happened 4 more times as I was coming up to stop lights and to park. It seems that it isn't reving high enough when I pull the clutch in. It hovers above 1K and then just falls flat in about 2 seconds. Shes got 17000 miles on her and no problems yet.
What could this be? Thanks
Getting Back
Have you adjusted your idle? Does it idle lower than normal when it is warmed up???
Its Master To You
Discussion Starter · #5 ·
Have you brought it in for the recall work? There was a throttle sensor that called on it. I think. I forget what it was, but it had to do with the idle and throttle.
No I havn't and I did think about that. Do you think they would still honor it a year later? It didnt do it on the ride home so we'll see....
i fixed mine myself,tps part cost 130..download the recall papers and it shows u how to adjust it..tank and airbox must come off..takes about 1 hr.that is if it is the tps causing your cut out...
Its Master To You
Discussion Starter · #11 ·
Went down to the dealer today, they said my VIN was covered and made an apointment to get it changed. It was much easier than I thought
1 - 11 of 11 Posts
