P
Not sure where in the US you're located but i have an extra master cylinder rebuild kit if needed. Located in Delaware
I can't imagine you mean for free. I am in Arizona. I will PM you. I am interested one way or another definitely. I have put SS lines on and bled for many hours and configurations, replaced bleeder valves... tried by pump and by hand... fresh fluid... and its bad. I took it for a ride today and actually leaving the highway coming to a complete stop (85mph or so to 0) I couldn't totally stop at the stop sign. I just turned and acted like I meant to lol. I stopped like I am used to stopping and it didn't quite cut it. It's fine for commuting around town but clearly not for taking it out for a good time. I am worried about breaking something pressing too hard and being screwed. The really weird thing is though, I am now having the similar problem with the back brake... in fact I have no back brake. I put in a SS line to the back. It has basically no fluid pressure coming out, constant infinite air bubbles. I can't tell what it's pumping air in through. Nothing is leaking. I have never had this problem with any bike. I put the oem hose back on and the back is acting the same. Really strange. I have bled brakes for a handful of bikes and never struggled like this.
The sucky thing is my fuel pump just went out on my 954rr. I have no car lol. I have to use the r1 until I get the replacement fuel pump installed, hopefully Wednesday.
One question... I took the spring clips off both front and rear. Could the lack of spring clip be contributing to the weak brake up front?
You can also try squeezing the air out. Take the cap off the reservoir. Hold the brake lever as tight as you can, then wrap the lever so it stays in place. Leave it like that overnight. I've done this a few times when bleeding doesn't seem to get all the air out and the brake isn't as stiff as I would like it.
I am currently doing this tonight.
The next time I work on the brakes (after I replace the fuel pump in the 954, lest a caliper seizes on me and I have no ride lol) I think I might be doing the reverse method with a syringe. Kind of curious how this works with two lines, though. Would I start on one end for a short bit, move to the other side, back and forth? Or just fill slowly all the way to the reservoir?
I have recently rebuilt my front callipers after the bike was stood for many years I know it had slightly spongy brakes before I put it away and had play in the lever similar to what you speak about,after bleeding for what seemed like an age and scratching my head till it was sore I realised my discs were warped and was never gona be able to bleed them.pull your lever in and look at both callipers see if onecaliper is gripping before the other you could notice that one side of your pistons in the calliper touches disc first and will see the disc move slightly indicating warped
The only reason I don't think this is from warped rotors, is when I pump the brake it gains lever pressure (without bleeding) and stiffens up and I get less and less travel in the lever... and then it loses it 10 seconds later. When I had bent rotors, it would lose pressure from moving the wheel. Also, no pulsing on brake. But OK, I will look at how the calipers are gripping.
PS I am no longer getting infinite bubbles in the front brake, like the back, after switching lines and bleeder valves. That is unique to the back. The front bleeds normal in the end now, and it just sucks keeping pressure and is very weak. The back will bubble every single time, forever, with zero lever pressure. I have swapped lines and bleeder valves for the back and it continues to suck ass.
