1 - 5 of 5 Posts
I can still slap you on my ZX7
Okay,
This just happened two hours ago and has been doing it since.
I go to shift, and it feels like it is in top gear when it is in third. The shift lever doesn't budge. I can't shift it. I let the clutch out, rev the engine, and try it again and I then can shift.
Then it will do it again on the next gear.
Downshifting is fine.
2500 miles. transmission hasn't been beaten THAT hard, just a little.
Oil should have 1000 more miles on it.
Any suggestions?
No, the clutch is not sticking. The shift forks are. I think.
see you at the races and ride
adjust your shift lever down for a more positive shift, check freeplay on clutch and be certian you are allowing shift lever to return after each shift. Gearboxes are only as smooth as the rider. Good luck
1 - 5 of 5 Posts
