1 - 3 of 3 Posts
Okay so I have 2 separate issues with my R1
The first being the dash, only the neutral light and turn signals work.
The second, Bike won’t start in gear only in neutral. (Clutch pulled and kickstand up)
The Kickstand being put down will stall bike if I’m in gear still.
Would love for some help as I don’t want to ride it till it works properly!
Rattus Gymnasium
Check to make sure the plug is seated all the way; or just remove the plug and check for broken pins, broken wire(s), or it could that those bulbs are burned out...
Check the Side stand switch and the clutch switch.
Service Manual
Ok, so I was able to get it started in first gear. I adjusted the clutch cable and now it starts right up.
Will be looking at the dash now.
Is it just the one harness or is there another harness in a different location?
1 - 3 of 3 Posts
