1 - 8 of 8 Posts
Hi All
Well after doing a search on the clutch slider i am a little confused?? Graves and motovasion are what i have found. The graves instructions says remove the nut on the swing arm....wait this is not a nut.. i need a special key tool to remove it right. Motovasion has a kit that uses a metal rod that fits through the swingarm, with a slider on both sides. What would you guys recommend i only need this slider to protect the clutch if i drop it.
Reckless
Motovation does not require removing the swingarm nut. The Motovation clutch slider goes on the clutch and the shifter side. It seems pretty beefy I also have the Frame Sliders and the have nice mounts.
Born to do trackdays
For the 2007 model they supply a bolt that runs the length of the swingarm pivot, from side to side. No more anchor bolt, or undoing the swingarm pivot nut.
1 - 8 of 8 Posts
