1 - 2 of 2 Posts
Has anyone done the swap i know it can be done with enough money but at that point i just buy a new bike 00 motor has a hole in piston #1 so its a no go and i found a 07 dirt cheap that runs good can the swap of motor and wire harness be done
Is there anybody out there?
Why not replace bad parts? You could go the 07 route and I'm sure it would be a lot of fun. Does the 07 motor come with everything or just the motor? You would need a fuel pump, which is in the tank, ECU, tip over switch, injectors, EXUP servo as it might not be the same as the 00 along with an EXUP for the 07(I'm guessing), speedo, temp and pressure sensors and a few other things that I'm not thinking about. Good luck.
Mark
1 - 2 of 2 Posts
