1 - 10 of 10 Posts
I am my battery's tender.
"Open or short circuit of steering damper solenoid lead."
Did you mess with the steering damper at all on your "20009 R1 Raven Black"
2009 R1 Raven Black
Discussion Starter #4
I accidently plugged the negative to the positive terminal which caused the esd fuse to blow. Thanks for all the help everyone.
Motorcycle Affectionado
HI do you know what error code 70 is related to allso. Thanks.
Straight from the owners manual:
This model is equipped with an engine auto-stop system. The engine stops automatically if left idling for 20 minutes. In this case, the multi-function meter indicates error code 70, but this is not a malfunction. Push the start switch to clear the error code and to restart the engine.
Holy balls... who leaves their bike idling for 20 minutes?!? :crash
1 - 10 of 10 Posts
