1 - 4 of 4 Posts
I have a 09 R1 and I'm switching the stock stabilizer out with the Ohlins SD024 stabilizer. The thing is my ecu is flashed, so the question is will it work or do I have to get a reflash?
Super Moderator
The question is the stock one was turned off I believe with the flash, so in order for the online to work the ECU needs to be turned on?
Super Moderator
If it was already turned off, then you don't have to worry about it.... It's basically not there so it doesn't matter what damper you install now.
1 - 4 of 4 Posts
