DRAG RACING part 3
Jeff brother you are cool as hell....lol
You know usually people on the internet have a tendency to LIE:bs However you are an honest guy. I dig it brother.
I Drag race when ever I get a chance. I do it maybe once or twice a month when the track is open. Sometimes more, sometimes less. I have run my bike maybe 50 times. I really don't know.
You have some killer 60ft times. My best ever on the R1 is a 1.7760ft. I am not a 60ft artist...lol I know that when I leave at 7k and slip the clutch alot I have higher trap speeds. Not by alot but it is noticable. Seems I can get a decent 60ft, or a good mph, but not both.
I wanna say I am in the top of 4th when I cross the line. I have never really thought about it before. I just watch the tach and shift when I get to my pre determined rpm. I was shifting into 5th about 100ft before the line, but realized that it was costing me about .05
I had Ivan's jet kit in my bike before my full exaust and I ran a best of 10.26. The jet kit does not really help on top. I Do not see it shaving off alot of time. A slip-on and the jet kit will help, but like you said not .5 worth.
I will tell you this. I have found this to work for me. When ever I go to the track I always dial in MAX rebound dampening in the forks, and MAX rebound and compression dampening in the shock. I also run my shock on the stiffest setting, street or track. This has shaved about a tenth for me. I hope it will help you as well.
As I said I also am using a one tooth smaller front sprocket. I know this helps. And I use the HIGHEST tire pressure possible in the rear tire without it spinning. Truth be known I can use 35psi cause I come off the line so slow...lol I also make sure the front tire is 40-45 psi. I remove everything from the trunk. I also try to keep the tank empty, to just where the light comes on. I get the light to come on, then add about 2 cups of gas, then the light comes on and I do it again. Just trying to help out the power to weight ratio.
I also run CR9EK plugs. I think they are better. You do not need to worry about indexing the plugs as they have two electrodes. I have removed the air pump and pluming, and trashed every extra hose on the bike. If it dosent help go, stop, or turn I try to get rid of it.
Where are you located? It would be cool to meet at a drag strip somewhere this summer with some other R1 guys. Good luck.
