1 - 4 of 4 Posts
So need help with my 2013 r1
Starts up but when I let go of clutch bike turns off (neutral)
Also does the same when in first gear( kickstand up) I bypassed the clutch & and kickstand. Any ideas ?
Yea my first idea is that the kickstand isn't bypassed correctly but that shouldn't matter in neutral unless the neutral switch was bad also. Is it showing up green on the dash for neutral or just N on the gear indicator cuz they are a different sensor
If you go into the diagnostics, one of the settings will tell tell you whether the bike thinks it's in neutral. What does that say as you change from neutral to 1st etc....
1 - 4 of 4 Posts
