1 - 4 of 4 Posts
Hi new to the forum and have concerns about the right hand engine mount on my 2019 r1. I installed woodcraft frame sliders and noticed that after putting on the right side there is a gap between the frame and engine. Wondering if this is how it is supposed to be or if something is wrong? Installed one side at a time and torqued to 51nm or 38 ftlbs
Have all spacers in but the cones on spacers are faced in on middle spacer, that's how it was when I took it apart but that's not what it shows in that diagram.
they face in. the motor needs to be tight to the left side of the frame to align the chain. the whole right side has spacers that on the back screw in to hold it tight and on the front one there you just tighten it up and it pushes against the motor then expands to hold the frame. the right side should be fine wherever it ends up as long as the bolt is tight and spacer is against the motor.
1 - 4 of 4 Posts
