1 - 4 of 4 Posts
Need more Boost
I was told to install on #1 cyclinder 8" down from Port. Problem I am having is there is no room. Trying to figure out how well it will be after pipes come together after the exhaust valves
Thanks Joe
kickin' at the darkness
uhm.. most of us run an AT bosch sensor at the 'midpipe' where all 4 collectors eventually end up.
this is just a random example of yer typical y-pipe showing proper 02 sensor location / angle, etc.
at least its an easy way to get a tune for all 4 cylinders.. the AT units only come in 'single' o2 sensor and DUAL o2 sensor..
are you planning on tuning all 4 cylinders separately? i would not bother.
Need more Boost
I still have the stock exhaust. All four go right into the exup then under the engine short pipe then to the slip on pipe. I was looking and think I found a spot right after the exup under the engine. I have the at-200. 1 sensor.
thats what i figured. the at-200 is the most common.
1 - 4 of 4 Posts
