1 - 4 of 4 Posts
Hi all
I'm new to the forum, looking for some advice . I have a 2000 reg R1. If i dont use it for 3 to 4 days the battery dies , its been to the garage and had a full check over with volt meter , the verdict was that every things is working fine , its because the dash on this model is always live so that is what causes the problem , advice was to put a descent battery on it as the one it came with isn’t the top brand. I bought the bike from a friend hew says thats not the problem , i trust the garage as has a good rep and in my area he is well known for being a great motorcycle mechanic and also trust my friends opinion that is isn’t the dash causing the battery to be drained .
And everything has been checked on a volt meter . Out of ideas...
has anyone else had this problem?!
Just looking for some other opinions on this .
thanks all in advance
Stuart
Moving sucks...
Hi all
Stuart
Assuming your battery is a lead-acid type. Buy a Battery Tender, wire up the harness so the connector is outside of your bodywork zip-tied and out of the way. If you're not riding the bike it should live on the Tender.
3-4 days indicates a short imo.
Ohm the harness to ground and if that turns up null ohm the sensors.
All a volt meter will do is exactly that, measure voltage. The amount of voltage indicated on a volt meter is not an indication of battery health, in terms of holding a charge.
I have the same bike as you. To the best of my knowledge, when the ignition is off, the only power used, is a small current to the digital clock, not enough to drain a good battery in 3-4 days. The odometer miles, including the trip mileage is stored in the ecu.
It sounds like a new battery is in order. I have bought one battery since I have owned my bike since 2008. I replaced the battery in June of 2018. My bike is hooked up to a battery tender, like Moonlighter said. I have the connectors permanently hooked up to the battery, and discretely zip-tied.
1 - 4 of 4 Posts
