1 - 4 of 4 Posts
first things first my battery wont hold a charge.when i have a jump box hiiked up to it it will start and run in idle just fine.But the lights will flicker.When i take the jump box off the cluster will come on and off and the tack will jump and when i go to give it throttle it cuts out constantly.but will idle just fine.after about five min. the bike will die.If anyone can help that will be greatly appreciated.......thanx....
P.S. i have a battery out of a six hundrend in it.
M.R.2.R1s
I can almost bet its a burnt wire on your rectifier. Check the red wire where the headlight plugs into the main harness. It has a issue with burning inside the connector and causing problems are the rectifier later. Check em both.
Regard,
Derek
1 - 4 of 4 Posts
