Hey guys, a while back I picked up an R1 that has been wrecked pretty bad. I have since replaced everything to get it riding, but it feels very down on power compared to my CBR600. In warm weather here in Florida, the bike will crank a bit then finally start (choke will make it not start at all). It rev's freely when not under load, but as soon as I ride it and do a pull it accelerates somewhat normally (although slow compared to my CBR) until about 4k RPM. Then it will hesitate/feel down on power a bit until about 6k, but takes off really quick after that until around 10-11k RPM when it will basically cut out completely like I hit the limiter. If I stay in the throttle it will work past it eventually but I didn't want to push it in case it was running lean.
Along with this issue, it has been coldish here in Florida recently. When I tried to start it in around 45 degrees it just cranked and sputtered, no start at all, it wouldn't even sputter with choke on.
The bike only has 18k miles on it, a shorty exhaust with very little baffling, no idea what air filter is in it, or if it is jetted for any of the mods. But there is almost no popping on decel so that points to AFR being in the ballpark. It was also sitting for around 6 months after the wreck and the gas smelled pretty varnishy, which has since been replaced with fresh. I have not inspected the carbs so I am not ruling out a clogged jet or 2. But since it runs ok in certain RPM's I thought I would ask for some opinions to see if there is anything else that could be causing this before I take them out and clean them. I would also inspect the plugs at the same time. I have confirmed the exup valve is present, but have not been able to check for correct operation.
Any help would be much appreciated, thank you!
