1 - 14 of 14 Posts
if u dont have any error codes.
then please
check for sparks on plugs
check the timings on cams and crank
check all 4 piston compresions
check fuel pump pressure
check voltage on each fuel injection.
if all good
then
make sure ur tps is above 19 it should be around 18 to 21 u can see by holding the select and reset botton then switch on key while still holding.
if all is correct.
then i suggest u make sure there is no dirt in the fuel line and injections.
and finally
if all is good.
i suggest turn u key and start ur engine and riving the hell till it starts.
i rebuild alot r1s since 2013
goodluck
tps garage
Super Moderator
The 02 R1 was the first with fuel injection. FACT!
Numbers must of been drinking that day and jsp just followed numbers down the road.
02 FI??? What I thought all motorcycles were carbureted, thank God for smart moderators!
Btw, it reminds me of wet fouled plugs. I'd start there, then work backwards from there.
Remember-Suck, squeeze, bang, blow.
then please
if all good
then
if all is correct.
and finally
if all is good.
goodluck
tps garage
Holy hell, great troubleshooting!
1 - 14 of 14 Posts
