2002 Yamaha R1 Suspension Settings
Rider Weight: 163lbs with gear
Front
Pre Load: 2 large lines
Rebound: 3 clicks out
Compression: 19 clicks out
Tire Pressure: 32psi
Note: Raised Forks 15mm
Rear
Pre Load: 1 indent from minimum
Rebound: 15c clicks out
Compression: 17 clicks out
Tire Pressure: 33psi
Note: Replaced oil in the rear shock. I went from the stock 2.5 weight to 5 weight.
When we pulled the shock apart the stock oil looked like “Beer Foam”. The shock is much more consistent now.
Steering:
I tightened the steering stem. It loosened up quite a bit during break in. I also installed an Ohlins Steering Dampener. I run the clicker at 5 clicks out.
Handling
The bike is much more predictable and forgiving. Late braking and mid corner braking does not upset the bike as it did before. The rear wheel is planted solidly when exiting turns and allows for more power to be applied earlier with out as much loss of traction. Powered drifts are easily controlled without that scary feeling. I found that the box stock settings are more for 2 up ridding. The rear was way too rigid and the front was too soft.
I really enjoy riding the bike a lot more now and it inspires me to push the limits with confidence.
I hope this helps anyone who is looking for a base line to start with. Also remember every one has preferences and these settings meet mine.
R1-Rowland
By the way I ride quite aggressively and push my tires to their absolute limit. I have been ridding over 23 years.
:thumbup
Front
Rear
Steering:
Handling
R1-Rowland
:thumbup
