Status
Not open for further replies.
21 - 40 of 40 Posts
Discussion Starter · #21 ·
That is because of the bolt pattern on the rim.You are right .There is no modifications needed to bolt the forks. send me your email and I will send them.
Ya whatever, save it
Rod.... the LE's use Marchesinis with the race bolt pattern... 6 x 80mm bolt circle basically the same wheel you'd buy as a direct bolt up without the adapters bolted on the run the large bolt circle you see on all the street going R1's
First image - Marchesinis directly for an R1 ( note the adapters bolted to the wheel to allow stock rotors )
Second image - Mor elike what the LE's come with except of course that is a 5 spoke wheel but look at the bolt pattern
You probably knew this already but it might help someone else
Moderator - In Memorium
Pics posted for kbob:
Discussion Starter · #36 ·
Items I have left are power commander.Hotbobodies with integrated tail light.Two bros carbon fiber slip ons with gutted cat.everything else sold.
Sounds great. You can either let the thread hopefully die off, or ask a Mod to close it.
The Mods in this forum are Irishstu, Solidus, Kevap, AnonymousR1.
The Goldenchild
Kbob, I see that you still have a couple of items left, are you wanting to close this thread?
21 - 40 of 40 Posts
Status
