Started my bike the other day turned it off went to start it again press the starter button and the check engine light stays on with pressing starter button but no fire please help
Yes ran fineDid you try pop starting it
Did nothing new batteryCharge/Check/Replace battery.
New doesn't mean "good".Did nothing new battery
I can attest to this. Went cheap on the first battery I bought, did nothing without a jumpstart. Bought a firepower lithium for like 140 and now it fires right back up. I also had to replace my relay,turns out most aftermarket relays are wired backwards and OEM ones are impossible to find at least they were for me at the time. Likely cause is a battery, what matters most is CCA or cold cranking amps. My new battery is 220 CCA. I looked into the Shorai batteries but the Firepower battery had more CCA and a slightly lower cost.Did nothing new battery
YesIs it the original stator and rectifier?
More than likely what the problem is, this is what mine looked like just about a year ago. View attachment 1018253 View attachment 1018254
