1 - 7 of 7 Posts
Hi guys,
I have read most of the threads relating to my problem with no luck. I have a 2006 R1, it has been running fine no problems at all and the other day I got home from work and thought I will take it out for a ride... it had other ideas! I turned the key and nothing happened... literally, it was totally dead, no dash sequence, no fuel pump priming, not a single light, no dash response, it was totally dead! I have checked all things I can think of, battery - ok, fuses - all ok even the main fuse under the seat. In my process of diagnosis I even turned the ignition off and on a few times, the only respond I get is the tach needle cycles when the key enters the off position. Has anyone had this issue and if so how the hell did you fix it ? Can anyone help me figure this one out? Please help.
Cheers
Is there anybody out there?
Sounds like your main switch could be bad. Trace the wires from the ignition(key barrel). Should be a plug near the front of the bike. Unplug it, turn the key on and measure the resistance between the brown and brown/blue wires(main power). Should be less than one Ohm.
Mark
Discussion Starter · #4 ·
Mark
[/QUOTE
Thanks so much for your guidance, I decided to start at the beginning and got the multi meter, battery load tester and a jumper start boost kit, I discovered the battery tested ok 12+ Volts but still no power, so I hooked the jump starter kit and got ignition sequence, lights ect.... it would fire but die in the same instance!!! So I load tested battery and it failed miserably, (big sigh of relief) removed the battery and it was badly swollen, replaced with a new one and BINGO!!! We’re back on, tested the battery while running the engine and it measures 14+ volts ? Is that nominal ?
It might be the ignition switch. I had a problem years ago where my bike would completely shut itself off with zero warning. After doing lots of unsuccessful digging I replaced the upper triple and lock set (which is easier than just trying to replace the lock set). After I replaced the upper triple and ignition, the problem disappeared.
I never opened up the old one, but it must have corroded or whatever from living outside for so long.
1 - 7 of 7 Posts
