1 - 6 of 6 Posts
1008366
1008367
Hi guys! I recently bought a used 2010 R1 and as I was adjusting the preload, the left collar sticks out longer than the right (pls. refer to attached photos) eventhough I turned the same number of times. Is this normal because of the left & right damping adjusters or does it have some loose nut or clip that’s why it’s sticking out more than the other? Thanks in advance!
Astronomer not Astrologer
That's bad, it may be disconnected from the damping rod, or it is serviced and not assembled correctly.
Discussion Starter #4
It doesn’t seem disconnected as the collar still retracts when preload is fully turned (to hard), and both collars will also be even.
Super Moderator
You might want to send off the suspension to Thermos Man being that the suspension is 10 years old and probably never been serviced. If there's anything wrong, he will find it. Good time to do it now for the winter.
This is a great idea. I had Thermos Man install and setup my Ohlins 30 mm cartridge kit. He has helped a lot of people just like you and I. Just contact him and see what he says.
https://www.thermosman.com
This is still not correct. If it were functioning correctly it would look like the other side. If you take the cap off the forks and disassemble the cap you can make it look like this.
I still think something is off on this fork.
1 - 6 of 6 Posts
