Hello everyone,
I am having an issue with my headlights not turning on. I have no headlights and no highbeam indicator with the bike running. I have run through the checks in the service manual for fuses, main switch, dimmer switch and relay. I found one blown fuse but that was for the fan which I replaced, I have continuity through the switches and the relay clicks and has continuity when 12 volts is applied. I checked the socket the relay plugs in to and I have battery voltage across the Red/Yellow+Yellow/black wires from battery and ECU. With the relay testing okay on the bench I SHOULD get power to the light sockets but I am not. Any chance the relay could bench test okay but still be bad? Possible bad wire from the relay to the light socket? Thanks for any help.
