1 - 9 of 9 Posts
So this is how it started ,
Filled up with gas and rode maybe 30 minutes the bikes starts to feel like it is mis firing every now and then , I think oh great crappy gas.
Another 30 minutes bike starts to become hesitant 5-6000 rpm . About 10 minutes out from closest gas station buddy behind says some smoke out the pipes ( light blue )and he can smell gas , so we pull over and stop . Gas can be seen dripping from lower exhaust joint (shit) Got it towed home , I am going to pull plugs and do compression tests etc , bike still starts but gas still leaks ( only tried for few seconds ) anyone know part number for fuel pressure regulator ? Anyone have anything similar happen or ideas please throw it out there , cheers for any help , I just want my beloved R1 back on its feet :)
1013279
Discussion Starter · #2 ·
So quick update #2 cylinder is wet
Tested coil packs
Primary resistance specs
.85 - 1.15
Mine all at 1.3
Secondary resistance specs
8.5 -11.5
Mine all at 9.3
still got compression test to do and check fuel injector for leaks
Possible a new plug failed and just got flooded ?
probably done 1000km on new plugs before this happened.
Discussion Starter · #4 ·
Thanks for the reply
Just tested compression , had to hold it in due to being worried
1013483
about wrecking the threads in the head , but I think it looks good
Mine was doing the same thing. Had to buy new PCV and fixed the overloading. Now only the center two headers are get hot. Still trying to fix the new problem
1 - 9 of 9 Posts
