1 - 4 of 4 Posts
All right I have a 2012 Yamaha R1 with Power Commander V fuel injection module shorty exhaust no cat K&N air filter about 40,000 miles on it and during the winter I was having trouble starting it come to find out it was the valve adjustment I've adjusted the valves are good the bike runs good the other day it started Dragon when it was starting thought it might be the battery not so is the case since then I have replaced the starter relay and the starter here's where I need to help I got it all back together any cranks but it doesn't fire cranks but it doesn't fire my power commander is no longer getting power to it and the fuses are all good does anybody anybody know what might causes fuel pump relay smoked or or what appreciate any help I can get
When you turn your ignition on (with the kill switch also switched on), do you hear your fuel pump prime for a few and then stop?
Sent from my SM-A305F using Tapatalk
Discussion Starter #4
I hear a click and a whne kinda but it doesn't feel or sound like its getting should spray out of that freaking fuel line if you got disconnected you trying to start it gas should be everywhere
1 - 4 of 4 Posts
