Forgive me in advance, still learning the dynamics of this site.
My girlfriend bought me womet-tech frame sliders, never heard of them but they look alright for now! I installed right side perfectly fine.. removed left bolt and immediately tried replacing with slider bolt and found the engine shifted (down) nearly 2mm!! The factory bolt was NOT cross threaded but the threads in engine looked questionable! I tried to jack the engine (bike not tied down, had my brother 215lb sit on it) got the bolt almost all the way in but it stopped! Tried to remove it and learned my mistake, (uneven pressure) caused it to bind.. finally got it remove and found thread damage!! Fck!!! Has this happened to anyone else?
I was able to barrow a trailer, strap the bike properly, support the engine, loosen right side mount and raise the engine into place! Used a tap, same size as factory bolt to clean threads, didn't have a die, so used a nut to clean up the bolt and threaded right in, torqued to 38ftlb (I don't have NM):frown2: and I'm hoping it's good to go!
Before I joined here I read a few others had this problem but cant find the post! Sorry for the long winded post, but I just want to get it out there, incase this is a common problem, possible side effect from the recall for 2015?? Im sure the engine was removed for that? Also was I supposed to support the engine prior to removing 1 bolt at a time, kinda seems like I should have. Done a few in the past without supporting, maybe I got lucky!
