I was reading through the 2015 R1/R1M Technical Update and pulled some interesting/noteworthy information:
Oil
-Yamalube 15W50 Full Synthetic
Engine Hardware
-Aluminum engine cover bolts are not to be reused if removed.
Intake manifold flapper valve to meet noise emissions
-Opens at 7,500 RPM, closes at 7,000 RPM
Electronic Racing Suspension (ERS) on R1M
-Suspension Control Unit adjusts Rebound and Compression
-Preload is manually adjusted. Applies to front fork and rear shock.
Cast magnesium wheels
-Touch up any paint flaws/damage ASAP to prevent oxidation and additional wheel damage.
-Aluminum plate placed between brake disc and wheel to prevent water intrusion and rapid corrosion due to dissimilar metals.
-Gaskets in place on rear wheel sprocket carrier mounting towers to prevent water intrusion and subsequent corrosion. Gaskets must be replaced in sprocket carrier is removed from wheel.
-Separate rear brake disc carrier used. No gaskets – thread locking agent prevents water intrusion.
R1M body
-Dry-carbon fiber used for front fender, upper cowl and side cowl
-Dry-carbon stronger, lighter that wet-carbon, but 3-4 times the cost to produce.
LED headlights
-Not serviceable. Must be replaced if LED fails.
-Lights and control units are easily removable for track-day/racing.
IMU Inertial Measurement Unit
-One-piece unit located under the battery.
-Handle with care – do not drop or subject to strong shocks.
-Do not attempt to clean the IMU with a chemical spray and/or compressed air. May damage breathable membrane.
-Changing the battery to one of a different size (such as lightweight lithium-type) will affect the vibration condition around the battery box, which may cause the IMU to not function properly.
Communications Control Unit (CCU) and GPS Receiver
-Allows rider to capture ride data
-Y-TRAC app for smart devices
-Y-TRAC Data log viewer - analyze and compare logged data.
-Send YRC setting to the bike via Y-TRAC.
-Save YRC settlings for each circuit with tuning/setting notes via Y-TRAC.
-Y-TRAC supports Android 4.2 and newer (available now) and iOS7 and newer (available late Spring 2015). Does not support Windows mobile operating systems.
-Set sampling rates for logging via CCU Config
-AutoLap setting – preload and configure race courses for automatic lap counting and timing via CCU Config
-CCU Kit for standard R1 models: includes hardware kit, seat cowl and pad, CCU mounting brackets, CAN bus cable, GPS receiver, and CCU. Pricing and availability TBA.
Traction Control System
-Adapts based on lean angle – more sensitive the deeper the lean angle.
-System monitors front wheel speed sensor, rear wheel speed sensor, IMU lean angle, and throttle grip opening angle.
-Engine Control Unit (ECU) can manipulate YCC-T throttle control (reduce throttle blade opening), ignition coil control (retard timing) and fuel injector control (reduce injection duration) to mitigate traction loss.
Slide Control System
-System monitors front wheel speed sensor and IMU slide detection.
-ECU manipulates ignition coil control (retard timing) to reduce slide and maximize drive.
Lift Control System (LIF)
-System monitors front wheel speed sensor, rear wheel speed sensors and IMU front pitch up rate.
-ECU can manipulate YCC-T throttle control (close throttle blade), ignition coil control (retard timing) and fuel injector control (reduce injection duration) to reduce front end wheel lift.
OHLINS Electronic Racing Suspension (ERS)
-Manual mode allows for rider to fine tune damping adjustments to suit riding conditions.
-Automatic mode allows for the semi-active suspension to continuously adjust the front and rear suspension damping forces based on brake pressure, vehicle speed, acceleration and lean angle.
-System monitors rear wheel speed sensor, IMU lean angle and acceleration, and front brake pressure sensor.
-Suspension Control Unit (SCU) controls suspension valve actuators to adjust front and rear damping.
Power Delivery Mode (PWR)
-System similar to D-mode throttle system found on 2009-2014 R1.
-Four modes change reaction speed of throttle blade opening with respect to throttle grip position. 4 is slowest reaction, 1 is quickest reaction.
Launch Control System (LCS)
-Once activated, the system monitors front wheel speed sensor, rear wheel speed sensor, throttle grip opening angle, and engine speed.
-ECU controls YCC-T throttle control (close throttle blade), ignition timing control and fuel injector control to regulate engine speed and power output to provide the best start from a standstill.
Quick Shift System (QSS)
-System monitors gear position sensor, rear wheel speed sensor, throttle blade opening angle, shift sensor and engine speed.
-ECU controls ignition timing (retards timing) during up-shifts to reduce engine power and allow for transmission to shift to the next gear.
-System only active when vehicle speed is above 12-MPH, engine speed is above 2,000-RPM and when the vehicle is accelerating.
-System does not function when the clutch lever is pulled.
-Allows use of GP shift pattern – shifter has a second pre-drilled hole for mounting shift linkage. Must 6mm x 1.0 thread pitch tap to finish pre-drilled hole.
Anti-Lock Braking and Unified-Braking System
-System optimizes front and rear brake force distribution.
-Rear brake force is reduced as lean angle increases.
-System monitors front wheel speed sensor, rear wheel speed sensor, IMU lean angle, and front brake pressure sensor.
-ABS electronic control unit controls hydraulic unit to control rear brake force.
-System is not active under 12-MPH
Oil
Engine Hardware
R1M body
LED headlights
