1 - 4 of 4 Posts
Hey guys. My 2016 r1 keeps shutting off when put in gear. Starts up when put in neutral but shuts off when put in gear. I bypassed the kick stand switch didnt work. Multimeter ed the clutch switch. When squeezed in I have zero resistance and when not touched the meter reads over load.
kickin' at the darkness
kickstand switch related i would think
but yes your switch appears to be ok.. its an on / off deal.. wide open load means super high impedance. or resistance.
SuperbikeUnlimited.com
you should't have any resistance through the clutch switch. it sounds like your kick stand switch isn't bypassed properly or the wire is damaged or something up higher. gear indicator sensor is only for the display. neutral switch bypasses kickstand switch and it starts in neutral so that should be fine. put the bike in gear and pull in the clutch see if it starts or will turn over. clutch switch is to bypass the neutral switch in gear and turn the bike over. if its not doing that the kick stand. did you check it for power and ground signals on the wires?
1 - 4 of 4 Posts
