1 - 4 of 4 Posts
Hi guys, I need some urgent help. I plug off the suspension box up under the right handle bar. Once I plug it on back I get ERR and the suspension diagram light. How do I reset this cause it working find before I unplug the box.
SuperbikeUnlimited.com
Make sure connection is fully seated. Unplug it again, make sure connectors are clean and listen for the "click" when reconnecting.
Make sure the bike is off when you do this.
Or just do what I do when I have to smog my car in CA, unplug battery for 30 seconds and reconnect.
Did all the above. Been at this for months now. My friend got one like mine, I plug it off and is the same problem. So the must be something to reset after it plug off. This is now happening to both bikes.
Check the ERS ECU. You can find it on the right side of the dash behind the plastic accent piece. Take that off to see it. You will need to remove the upper fairing to make sure the wiring is good/connected. If that looks good, you will have to find a shop.... yamaha dealer for that ERS system.
1 - 4 of 4 Posts
