1 - 5 of 5 Posts
I was riding my bike this morning and the traction control slide control abs check engine and the mph stopped working. Does anyone know what I could do to fix this. My bike has 14k miles on it. I do regular maintenance on the bike. Not sure what could be causing this issue. The bike still runs good just all the electronics stopped working.
all of those systems use the wheel speed sensor so that would be the first place i would check as he stated. after a quick visual check for any wear on the wire from maybe it coming loose and rubbing the rotor or something, maybe getting tagged with a rock. if nothing then download the service manual and find the procedure for checking the resistance of the sensor.
Having the same issue since last season. Mine does it at high rpm under wide open throttle, at the track.
Replaced the rear speed sensor and got the ECU re-flashed just in case.
Will find out in a couple of weeks if it's fixed and update you.
2016 5000km
1 - 5 of 5 Posts
