1 - 6 of 6 Posts
R1 Addict
So, recently my bike wouldn't start while in neutral unless the clutch was pulled in. If I released the clutch, it would die. If I had the clutch pulled in and it was running I would shift into gear and the bike would die again, while the clutch was still pulled in. Any feedback much appreciated. Completely stock bike.
take it back to the dealership where you bought it. has any work been done to the bike recently before this issue started?
hi, i met with the same issue b4, similiar as what u described. Initially i suspected might b ECU but there wasn't any fault code error or engine check light.... somehow, i do not really know i suddenly felt tat it might b the side-stand switch/sensor causing this issue. i went down to my frequent bike workshop and told the mech to by-pass the side-stand switch/sensor and wala.... everything back to normal again. But your ride is still very new since it's a 2018. Nevertheless... Hope it can helps u
Sounds like an issue with the side-stand sensor... assume your side stand wasn't down when you were trying this? :)
Yup..... my side stand wasn't down as i was at a traffic junction waiting for green light to move off. And the engine kept dying off every time once i engage 1st gear till i had to push and park the bike at the road side a distance away from the traffic junction and called for a tow truck....
1 - 6 of 6 Posts
