1 - 12 of 12 Posts
wheres the aux rev limiter?
Its changing the chain and sprocket size from a 530 to a 520 , less rotating mass= less gyroscopic tendancy=easier flickability, depending on what chain and sprockets you use it should shed about 3 to 4 lbs of unsprung weight.
Bulldogger
Search button my friend search. I did the conversion and like it alot. Never have to shift to 1st in the twisties, and wheelies on demand;)
Green Goblin
Discussion Starter #4
i did a search and all I found were post tell how they like it but not what it was exactly.
Green Goblin
Is the gear ratio effected at all?
if you want it to
basically the 520 is a slightly smaller/lighter chain and sprocket combo. you can choose to keep the stock ratio, or alter to your needs since you must purchase chain, front, and rear sprockets
Id recomend -1 in front and +2 in the rear... and yes, that combo will throw off the speedo
Wheelies for boobs!
VinR1 said:
if you want it to
Yep.....easy fix though, a speedo calibrator... :rock
Born to do trackdays
Green Goblin
Discussion Starter #10
Just when you thought . . .
R1 Tuner said:
you need to get the speedo calibrated?
Bone stock the speedo is off by about 6 percent (a little less if you put a 180/55 on the rear). If you change the sprockets from stock, then that throws the speedo even further off. But, as RUFFSTUFF nidicated, a speedo recalibrator will fix that. Less than $100 for a yellow box and easy to install. I'd recommednt eh speedo recalibrator even for stock gearing because the odometer is tied to the speedo. Thus, with stock gearing, you're adding 6% more miles to your bike than you are actually riding.
1 - 12 of 12 Posts
