1 - 5 of 5 Posts
Hey so I have a 99 R1. I have a skipping issue or missing issue when I get on the throttle sometimes not all the time only sometimes. I thought that the chain was loose so I did my judgment there and it is not the chain sliding I checked both my sprockets and it is definitely not a loose chain. I'm thinking it's either electrical or something major in the transmission if you guys have any advice please please I could use your help. Thank you.
What do you mean skipping/missing? Like it bogs down and misfires or that your RPMs jump, but you're not accelerating? If the former, it could be spark plugs or carbs. The latter could be a worn clutch that's slipping.
One Liter Duck Eater
I had the same issue with my 09. I took it in for some dyno time, and the tech noticed that the fuel line was kinked. Did you do anything under the tank recently?
I have the same issue on my 97 Thunderace. New chain and sprockets. New clutch. Still trying to figure it out.
Check coils to make sure they didn’t come loose. Happend to me on my 2006 R1. Pressed the coil back down onto the plug and all fixed
1 - 5 of 5 Posts
