1 - 20 of 1980 Posts
“Rhinestone Cowboy” MF Doom
Bought it like this...
Turned it into this...
Then this happened...
And now the rebuild. Stay tuned...... :corn
Mod list:
Updated April 6, 2019
Engine/Performance
•Öhlins Full Forks
•Öhlins Rear Shock
•Graves Suspension Link
•Graves LINK 3/4th Exhaust
•Graves Cam Chain Tensioner
•Graves Clutch Kit
•Graves YEC Race Clutch Springs
•Graves Smog Block Off Plates
•Grave Upper & Lower Velocity Stacks
•Brembo RCS 19 Brake Master Cylinder w/ Shorty Lever
•Brembo HPK Clutch Perch w/ Long Lever
•Brembo 320 HPK Rotors
•RogerSBK WSBK Carbon Fiber Air Plenum
•Power Commander V
•AutoTune
•Dano ECU Quick Shifter
•CABS Techtronics Autoblipper w/ Pull Sensor (Clutchless Downshifts)
•Domino XM2 Throttle
•Renthal Clipons
•Blue SAMCO Hose kit
•BPP(F) Renthal(R) Sprockets 520 -2/-1 (3.07)
•RK GXW 520 Gold Chain
•Superbike Unlimited ECU Flash
•HEL Performance Brake Lines
•Rear Brembo Caliper
•Fast Frank Rear Captive Carrozzeria Underslung Caliper Kit
•SBU Ultra Light Rear Rotor
•Amsoil Engine Oil
•Grave 2.0 Radiator Cap
•CV4 Gold Thermal Wrapped Fuel Tank, Airbox, & Plenum
Body/Accessories
•2012-2014 Headlight Conversion
•Zero Gravity Corsa Windscreen
•Locamoto Carbon Fiber Fairing Stay
•Lacomoto Carbon Fiber M1 Replica Tank Cover
•Lacomoto Rear Tire Hugger
•MDI Carbon Fiber Clutch Cover
•ZMotoSports Carbon Fiber Front Fender
•1CarbonTech Carbon Fiber Tank Panels
•Ducabike Carbon Fiber Brake Lever Gaurd
•Translogic Digital Micro Dash
•Domino Grips
•39N Racing Superbike Left & Right Button Pods
•Gregg's Mirror Block Offs
•CRG 1" Bar End Mirror
•Driven D-Axis Quick 1/4 Turn Gas Cap
•Driven D-Axis Oil Fill Cap
•Driven Preload Adjustors
•Custom Carbon Fiber Triple Tree Plate
•Pro-Bolt Steering Stem Nut
•Attack Performance GP Receivers
•Rizoma Front and Rear Brake Reservoirs
•Clear Tygon Brake Reservoir Tubes
•Graves Front Sprocket Cover
•Alien Motion Lithium Battery with Quick Disconnects
•Vortex Rearsets
•CustomLED Intergrated Tail Light
•CustomLED Bilnker Relay
•Watsen's Flush Mount Turn Signals
•MotovationUSA Race Cut Frame Sliders
•MotovationUSA Clutch Sliders
•Woodcraft Engine Case Covers
•Mo-Door Garage Door Opener Custom Install
•Morimoto 5,000K HID Kit w/ 5 sec delay Relay Harness
•Sharkskinz Race Tail with Tail Light Cutout
•Sharkskinz Belly Pan
•Kurvey Girl Dzus Quick Fasteners
•Stomp Grip Gas Tank Protector
•Stomp Grip Traction Pads
•Hand Brushed Swingarm
•LighTech Chain Adjusters
•Nomar Rear Reservoir Bracket
•LuiMoto Suede Seat w/ Gel Pad
•Chris Kruzel's DrippinWet Decals and homemade number plates
I'm sure I'm missing some stuff....
I RACE U LOSE
:corn
Hope is what makes us Human.
:scared WTF!
14k+ posts and not one helpful
Can't wait for this!
Did insurance cover any of the accident?
cant wait to see the finished product!! My first R1 was a rebuild(my buddy crashed and sold to me) and tbh it was an epic experience. I still love that bike to this day because I put in so much time on her.
Did you get your stretched swing arm ordered yet bahahahahaha
kickin' at the darkness
'16 60th Anniversary "Pikachu"
did you do a thorough inspection on your airbox? My airbox got cracked both bottom and lower when the gas tank took a hit.
looking forward to your rebuild. wished i would of seen that needed oem left control switch earlier, because I had that and ended up chopping it up for for switch mods on my son's quad lol.
Dara
Discussion Starter #16
Dara
You mentioned the airbox to me right after the accident I did inspect it and it was untouched.
Thank you.
You need to talk to your tyre fitter. Looks like he gave you a car tyre that fell off the rim.
Ok, I know this is laughing at someone else's expense... But, I laughed uncontrollably hard about that comment!
:hammer::hammer::hammer:
