1 - 7 of 7 Posts
Adjustable lowering link*****SOLD********
Soupys adjustable lowering link. $55
Fits 1999-2005 Yamaha R6
2006-2007 R6S
2002-2007 Yamaha R1
Our turnbuckle style lowering link will adjust the rear of the bike infinitely between stock height and a 4 inch drop. No need to remove the link from the bike...just loosen the nuts and rotate the center hex body. You do not have to remove bolts and find a way to hold the bike up while you are doing it! The body is stainless steel, NOT aluminum. The ends have a 1/2" thread and are zinc plated steel for strength and corrosion resistance. There are also 4 inserts that make up the difference in the diameter and length of the stock bearing setup. THIS IS A DIRECT BOLT-ON ITEM! The ball bearing is hardened steel with a Teflon race.
Khaos
will it fit a stock arm? i know i have a naarnen or somethin like that and it only fits aftermarket arms
1 - 7 of 7 Posts
