1 - 4 of 4 Posts
Did a search and only found some info on aftermarket ones. It seems like it can be done. I wanted to raise the shift lever up a bit from stock. With my boots on my toes is pointing too far straight down. Makes shifting with the Sidi's a bit of a hassle. Anyone know how much up/down play there is in the Stock Setup?
Looking at the bike today, seems I could raise it or lower it a bit but wanted to se if someone else had done it before tearing it apart.
Thanks
Action figure sold separately
Yes, you can adjust the angle of the brake and shift lever to suit your needs, and you should do this whenever you get a new bike. Same with hand lever reach and angle.
1 - 4 of 4 Posts
