1 - 20 of 24 Posts
Until it sleeps
I let it idle for a little bit. cuz i live on a dirnt road and dont wanat to drive fatser than idle on the gravel. so it get about of minute of idle vefoer shutdwon
Hey if id ont make sence im drinking please exucse me
Beating a dead horse.
you should always let an engine idle under hard use for a few min. its a very good idea
Do or do not, there is no try
I'm sure you all know this, but never turn a bike off unless it's at idle.
:beer
GO CHIEFS!!!
I just turn it off, but then again the twisties are a good 10 miles or more from home, so it gets lots of easy riding on the way back.
- BA
I need more money.
I live in an extremely hot weather and after the ride I just turn the bike off. If I let it work on neutral then temps are going up and up. I feel that it is better for the bike to be off then work at high temps in Neutral.
Thats only my opinion.
You have to idle turbo motors (to allow the turbo to cool down) but not normal piston motors. The liquid cooling of todays motors is so good that the motor probably will be cooler after running hard than after idling...
powderwhore
I just turn mine off. But I have been know to use a fan during the summer months.
If your fan is running, i wouldn't suggest turning it off right away, the coolant in the engine can soak up all the heat and something bad might happen.
:beer
I've never let it idle after riding... I noticed that if I let it idle for to long it will get to hot...so what's the point... I usually power down right after riding... while the temperature is still around 160 - 170...
it there any reason I should let it idle after riding to shut it down ??? :confused:
:confused:
shoots! scores!!
precisely. idling your bike after a ride is only going to make things hotter, not cool it down. just shut it off.
idling a motor to cool it down is nonsense, the only way itz going to cool down is if A) you are moving. B) itz not running.
pavement tester....
I mean think about it, my bike is probably ran the hardest at trackdays in the summer and when I pull into the pits i just shut it down. No idle or anything.... Never had a problemo
:confused:
Re-read my post. I didn't say let it sit and idle for ages, just don't shut the thing off while you're revving it, or the chokes on.
Stop and shut it off at idle.
:beer
we meat again
Yep... well said! :yesnod
Only turbo need to be cool down by keeping the engine running so that the oil can keep circulating to the turbo. This is why people use turbo timer, so that they can just walk away from their cars and the car will turn off itself after a preset time.
But there is no point for idling a N/A motor, cause the engine will even get hotter if you let it idle. The best way to cool down your engine is when no parts are moving, in another word, it's off.
...Is just so addicted to R1..
I don't get this...
In other words, you shouldn't like, pin the throttle and let it bounce off the rev limiter whilst turning the key to the off position???
What the hell was the point of this thread anyway?
:iamwithst
we meat again
Re: I don't get this...
:iamwithst
I think you misunderstood the question man... :yesnod
Nope..
No- that was just my sarcastic side kicking in....
besides- it wasn't even in repsponse to your comment- I'm with you on the no-point-in-idling issue!!! :finger
In truth, I never let mine sit and idle- only on warm up, but only to lower operating temp range. Maybe it's the paranoia that sets in owning a V45 magna... they have a terrible top end oiling problem- to the point where you're better of actually just letting it warm up to the point where it idles ok without choke and GO- let it idle on an easy warm up ride, rather than idling or low rev operation- not enough oil gets up to the top end and the cams go bye-bye...
:finger
Una Caterva, Una Pugna
I let it idle for about 15-20 seconds or so..... after a long enough period of time the temp is gonna raise from idling anyway.
powderwhore
I run a floor fan in front of the bike. Not the fan on the bike. Just an FYI
1 - 20 of 24 Posts
