1 - 2 of 2 Posts
So i installed smog block off plates/ k+n air filter on a 2019 and everything was ez pz. Reinstalling however is not the case. Everytime i put the air box on it rests in place misaligned, its raised up on the end near the handlebars. I have tried 3 times starting from the block off plates and going forward and i end up with the same result. The throttle body part aligns i can feel it slide into place but the air filter end is raised up. So basically my question would be to anyone who has done this and ran into the same problem what is the issue because i cant see any wires/plugs that would cause it to be misaligned.
SuperbikeUnlimited.com
Make sure that intake tray is fully seated. The tray leading the air to the filter.
1 - 2 of 2 Posts
