1 - 3 of 3 Posts
Vendor
Built on a race-proven design, the SMX Plus boot uses a contoured polymer shin protector designed for a comfortable and secure fit. It also provides excellent impact and abrasion resistance. Within the large shin protector, you’ll also find a strategically positioned front vent for improved. You’ll notice a large Multi Link Control (MLC)that adds impact protection to ankle as well. All of this is attached to an upper made with lightweight and durable microfiber, that’s mixed with synthetic compound for long-lasting durability.
1009186
Holding the boot on your foot is a ratchet buckle closure on calf features that has a hidden security strap as well as a lateral side zipper that’s covered by a long strip of protective leather. As you move down the boot, you’ll find anatomically designed, asymmetric leather accordion stretch panels that allow maximum flexibility without sacrificing rider safety.
1009187
1009188
Working with the inside of the boot to keep you cool, breathable mesh inserts and a perforated side panel allow air to move around your foot. This of course, is in addition to the perforated leather at dominates most of the boot’s exterior surface.
1009189
Keeping your toes safe, dual-density screw-in toe-sliders are carefully placed to prevent abrasion for those that corner low. Constructed of ionized aluminum and polymer, the combination provides durability and abrasion resistance. These units can be replaced when they’re close to wearing through.
1009190
You can order these boots and take advantage of expert sizing advice by calling TJ on 866.931.6644 ext 817, sending us a PM or a note to [email protected] with ALPINESTARS SMX PLUS VENTED BOOTS in the subject line, just be sure to specify the what size sneakers you wear and whether or not you want the waterproof version - and we’ll get back to you right away.
Vendor
Discussion Starter #2
In the picture below you will see the perforated leather that extends from from the arch of your foot through the instep.
1010268
Vendor
A good look at the lateral side zipper that’s covered by a long strip of protective leather. Call 866-931-6644 to order!
1013919
1 - 3 of 3 Posts
