FYI: Before you send them out, get a representative sample of the final anodized color, this is for a couple reasons-Mac R1 said:I am looking to ship out my stock rims to get them anodized in red. Was wondering if you guys know of any good places.
:iamwithstmartinc said:Transparent red powdercoat on a polished rim is,in my opinion,the only way to go;
Anodize will fade with time and since wheels are an item that we wash a lot (1st thing getting dirty on a bike) you"ll see the color disappear inside 2 years for sure.
Anodize offers no protection against rocks and such.
I wouldnt do it....
Boiling the parts in water for about 1/2 hour will cure this problem. This is sealing the anodization. Unfortunately many companies just skip this step to save money.Anodize will fade with time
What he said :thumbupmartinc said:Transparent red powdercoat on a polished rim is,in my opinion,the only way to go;
I wouldnt do it....
You could do that. You would have to check to make sure the powder coat would bond to the anodized layer.pkracer21j said:can't you anodize your rims then have them powder coated clear?
If you go for the clear powdercoat (it is available), make sure you specify urethane or polyester, they have excellent UV protection, hybrids & epoxy's do not, they will oxidize (chalk) with prolonged exposure to sunlight :thumbuppkracer21j said:can't you anodize your rims then have them powder coated clear?
Here's something else you should consider when contemplating the above, your cost savings are not going to insure it will be less expensive than buying a set of good used (or new) aftermarket wheels.rorlow said:If you go for the clear powdercoat (it is available), make sure you specify urethane or polyester, they have excellent UV protection, hybrids & epoxy's do not, they will oxidize (chalk) with prolonged exposure to sunlight :thumbup
Any reputable powdercoater should have sufficient pretreatment capabilities, to insure coating adhesion, I stress the word "Reputable" :yesnod
:dundun: umm, a 7 year bump to ask that?:ncont:Would any reputable company offer to anodize wheels? Is the material not unsuitable due to its grain structure and magnesium content?
