1 - 4 of 4 Posts
About a year back I was out riding and headlights and cluster went out. Wiggled the wires and they sputtered so figured it was in that. Got it home and after taking fairings off found the culprit in the connector box, loose arcing wire. Cleaned connector replugged wires and solved problem.
6 months later same problem popped up. Wiggled wires but nothing happened this time. Decided to just pull wires out and make my own connection. Still nothing. Checked fuses in fuse box and none are blown. Is there another fuse that I'm not aware of that could be causing the lights and cluster to not come on?
Discussion Starter #2
Figured there was no reason to post bike model since it's in the 07-08 sub forum but bike is a 08 Yamaha R1.
After ripping this thing apart found a wire was burned completely though behind headlight.
Took it out for some fun friday night adrenaline fixes afterwards. Love yamaha.
1 - 4 of 4 Posts
