Why wouldn't you get the right fork or re-valve the stock ones?As title anyone ever done this?
No offense friend!Anything can be put on anything if you have enough money and a good machine shop. As long as the fork is long enough it can be adapted. The steering stem is usually the only thing that needs massaging.
I think it's a waste of time.Sorry you feel that way, but it is true. The vast majority of the time it comes down to the steering stem. If you can get the correct bearings, and get the stem the right length (or get one custom machined), any front end can be adapted. I started on a FZR600, and anyone that road those hard, wanted a better fork. I have seen R1, YZF600, YZF750, Ducati , ZXR400, GSXr 750, 600, etc. forks mounted to the FZR400/600. Sometimes you get lucky (like the YZF600 and YZF600R) and the bearings are the same, and it just bolts up, but most of the time the steering stem is either too big, or too long/short and you have to get it machined or custom built. Other than that you have the length of the fork, and interference from the clip on position. A fork is pretty much a fork otherwise...
If you do that you will have to get the brakes at the same time, Ducati use 100mm and Yamaha 108mm. Then there's the fender and possibly wheel spacers and axle too remember. You could even get into rotor offsets and wheels.It may just work out cheaper to get ohlins of a Ducati and fit them as I'd like to run brembo calipers that's all
If you do that you will have to get the brakes at the same time, Ducati use 100mm and Yamaha 108mm. then there's the fender and possibly wheel spacers too remember, could even get into rotor offsets.
:fact.. Trying to be 'thrifty' often costs more at the end of the day..:icon_rolleyes:If you do that you will have to get the brakes at the same time, Ducati use 100mm and Yamaha 108mm. Then there's the fender and possibly wheel spacers and axle too remember. You could even get into rotor offsets and wheels.
This is all assuming the forks will even fit the triples of course.
