1 - 5 of 5 Posts
Save a life, grope your wife!
I did a search for them, but didn't find anything. If anyone has the error codes, or knows where they can be found, please post up. Maybe we can get a sticky thread done. I had a 14 error code today, but found out I had left a vacuum line on the #1 throttle body disconnected. But I, and others I'm sure, would like to have them.
So, thanks in advance to whoever can provide them.
TechnoPhiliac
Its in the shop manual: Page 8-37
Symptom: "Intake air pressure sensor: open or short circuit detected"
Probable cause of malfunction:
"Intake air pressure sensor hose is detached, clogged, kinked or pinched."
"Malfunction in ECU"
Looks like your hose caused it
I'm slow,but i may not be last
anyone knows where the links for the error code manual?
Hi! I sow in the 07/08 Service Manual and it say's that code 14 is relative to the following symptom:
•Intake air pressure sensor: open or short circuit detected.
•Probablem cause of malfunction: Intake air pressure sensor hose is
detached, clogged, kinked, or pinched. Malfunction in ECU.
•Diagnostic code # 03
1 - 5 of 5 Posts
