I was curious if anyone was spraying without the tuning for it and if so what were your results???? I did it last year on my 02 with great results.
I shot a 40 and it dropped my 1/4 down by .4 in the quarter
Is your friends kit wet or dry????my friend shoots a 35hp into a bone stock 05 gsxr and runs 8.74's
Wish I could find a place to tunes or let alone lets you just get a base run for those prices. I can't find anywhere less than 400.....thats outrageous in my mind. I got another bottle and setup that will go under the other side of the tail.yes with wet kit.. u really dont need it. ur adding fuel with nitrous via nozzles. but still it all depends on ur tune.. what ur A/F is. if normally ur bike is a little rich.. then dry shot with it should be fine. now if u have bike pipe, no air filter and such without PC and run dry shot.. well ur asking for trouble. its all how ur A/F is on ur bike. those at higher elevations can get away with more.. less oxygen in air and bikes will be on rich side. those closer to sea level there A/F should be little better on just motor. so adding nitrous will lean it out.. as always.. if u dont plan on running a PC.. put it on dyno... just to see what A/F is on motor and then spray it. as long as its within safe limits.. no problems.. what does dyno run cost??? $25-75... thats lots less than building motor.. better to be safe than sorry
