1 - 7 of 7 Posts
I just bought a new battery for my r1 07, and it died quickly. It doesn't want to start the bike I don't really know, please help?
Super Moderator
Sounds like a short. Take a meter and check your battery positive and negative to ground and see what you get. Any recent mods done on it?
No, but I noticed that the stator wire that's plugged to the regulator rectifier is extremely hot. I don't know why.
Discussion Starter · #4 ·
By checking my battery positive and negative to ground I got 12.70 V.
Now what is the next step?
Replace your voltage regulator, it is faulty.
I have also had this problem in the past, the unregulated voltage to your battery is overcharging it to the point of failure. I also explains the heat. A new regulator is an easy plug and play install.
Check your rotor. If you still have original rotor it is proned to failure where the magnets cone off due to the crap Yamaha design. I had a similar issue and it was the rotor. It may not be you issue but worth a check.
1 - 7 of 7 Posts
