1 - 10 of 10 Posts
Hi my 07 R1 cutout while riding at low revs, low speed. This locked the back wheel. No error codes that we can see, Ike won't start now, any ideas?
Discussion Starter #7
New battery, oil still fine, water fine but the starter has been giving problems
Okay. Starter doesn’t explain why it cut out while operating. After ruling out your starter, I think you are going to have a stator issue or some other electrical issue. The “wheel” lock up you describe worries me because you should be able to roll the bike in gear (2nd) or higher as if you were trying to manually start it. I’m assuming the wheel isn’t actually locked up, if it is, you have mechanical engine issues.
You are going to have to provide more details on bike history and what you have done to try and fix it or things you have checked. Until then. Bump.
1 - 10 of 10 Posts
